I actually meant the 27" cinema display, not the 24", but I guess they are the same.
What's wrong with glossy screens by the way?
Lacie 724 is where its really at...if you have a spare £2300 that is.
How come? Why would anyone want less screen space?![]()
It's nice to have a wider monitor to fit a landscape orientated image + tools either side in PS/Lightroom
No offense but I'm going to guess that you have absolutely no idea 'where it's really at', and you just went to find the most expensive LCD monitor on google and assume it's the best. The 724 is a classic case of having a uselessly big gamut - 123% of Adobe RGB with an 8bit panel is neither big nor clever.
SS: Glossy screens are bad for numerous reasons, but providing you've managed to get yourself in a perfectly reflect-less black space in the corner of your room, you've shut all the blinds and aren't wearing anything luminous.. Even then they cause contrast problems. They basically fake a higher contrast ratio, which is a nightmare when trying to print because the effect is very hard to reproduce. I guess in todays world where we display so much work on screen we're approaching also needing a reference glossy monitor, just to make sure it looks good on that too! But generally you're working monitor is exactly that, a reference. It's where you can make sure the file is good before making it's various alterations for prints or other display. It's no good having a reference that's lying too you.
But it is no wider - it's still 1920 pixels wide. All it offers is less vertical, which may offer the illusion of being wider, but you won't gain anything for your landscape shots - you'll just be zooming out of the photo more, thus being able to fit in more palettes.
DO NOT GET A TN screen for PP work
I love sweeping statements, me .....
An inexpensive but perfectly adequate display which is well calibrated and outputting to a
correctly profiled printer, can be more cost effective for non pro, (non colour critical) photographer
(that's about 90% of photographers - another sweeping statement - told you I liked em) than
shelling out for a £ 100's more for an IPS display, all things are considered.
FYI, you can't calibrate a TN screen well. The viewing angle limitation of the technology is so great any accuracy you achieved during calibration is easily outdone and more by simply slouching in your chair.
"Calibration" based on numbers has also been done to death, in the real world.
User posture has little to do with calibration 'cept on fora where posturing is essential
Anyone worried about colour fidelity 'within x budget' can't afford proper accuracy and anyone who really needs accuracy doesn't tend to worry about cost as they have clients who pay .. so they outsource and bill accordingly.
QED
There are great TN panels and rubbish IPS panels, both for the price and in terms of performance.
£100 spent on a large tin of flat paint, a decent light bulb and some blackout blinds can make more of a difference to a user experience of a display and make less expensive (more affordable) calibration tools perform better in terms of getting close to whatever is deemed as accurate.
That's assuming that the source image was captured correctly and the person paying for/viewing the image isn't colour blind, thinks it's a bit blue or wants it warming up a touch
Way too many variables to determine if X panel is better than Y panel in Z situation in the hands of A user.
For the average user the best advice is to buy the largest display you can afford and, if it's important, calibrate it as best you can.
The display will end up within a few percent of what an expert will classify as within tolerance but in the meantime you will have spent 80% less dollar and enjoyed many more games, movies and donkeyp0rn than said expert will as they are too hung up on micropercentages of accuracy.
U
A Dell 2209WA, for example, is a cheap but fair quality monitor, IPS, small enough to not really have severe problems with uniformity. You could buy a 24" TN panel, but I've not seen a single one that would be a better purchase than the Dell.
