are there ANY good LED 120mm fans out there?
11 Jun 2009
Bridgwater, Somerset, UK
Hi, Ive just discoverd i have a 120mm fan hidden in the front of my pc case..that ivehad for just under a year! .. lol (had to unscrew the front panel, brakets and then the dust filter to find it :O i was so shocked lol well the fan at the mo id say is under 50CFM are there ANY quiet (under 25DBs yet over 50CFM) 120MM fans out there ANYwhere? :( it would REALLY finish the case off nicely if i could find a green or red one :D thanks for any help you can give - Adam :)
Try the Yate Loon D12SL-12 LEDs.
Around 50CFM and quiet. I'm pretty sure that all the quieter 120mm fans are below 50CFM.
About a fiver each too.
i LOVE ac ryan! but they are a little loud for me :( also they only seem to use black lights with UV blades! -_- oh well i broiught an enermax! and brought some lazxer mod lights :D
Xigmateks are really decent LED fans, I've got 3 x XLF-F1253's fitted to a triple rad, and they keep my i7 920 and GTX280 nice and cool.
Here is the specs for them:
XLF-F1253, 120mm white LEDs cooling fan, not only catch your eyes but it also performs to add more air current inside your desktop PC's case. With Max 1500 R.P.M. and 61 CFM but only 20 dBA quiet level, its result is a lower overall operating temperature with very little added noise. The white LEDs and transparent color will make your case be a spotlight.
Details:
• Specific bearing design (Long-life Sleeve bearing) provides longer MTBF and outstanding performance.
• Optimal blade design provides the reduction of noise and power consumption.
• Transparent colorific blade and frame with White-LEDs make your case be a spotlight.
• Higher airflow, static pressure and torque.
• Reduction for noise and power consumption.
• 4 pcs White LEDs and transparent colorific blade and frame
• Dimension: 120(W) x 120(H) x 25(D) mm
• Voltage Rating: 12V
• Speed: 1500 RPM
• Air Pressure: 61 CFM
• Noise Level: <20 dBA
Sharkoon Silent Eagle 1000 Blue LED
