- 6 Jan 2012
yeah FIXED MODE is what you wantOk I see in OC Tweaker tab, CPU Core/Cache voltage and its at Auto and if i hit Auto it gives me Offset mode or fixed mode but I dont see CPU Ratio.
Thanks
Thanks
yeah FIXED MODE is what you want[/QUOTE
Ok if I pick fixed mode will I then see CPU ratio, I dont see it at the moment, sorry about all this.
fixed mode don't you get a multiply
no problem, give us a shout if no Asrock fan boys chip inNo, when i select Fixed mode I dont see a multiply option....well maybe its under something else, sure we'll wait and see if a Taichi owner comes along but thank you for your help so far
Thank you, will do.no problem, give us a shout if no Asrock fan boys chip in
Yes it will, if you don't mind the noise. My 100X is really loud on full fans. Are you still tweaking bios settings or no luck?I chaged CPU Fan 1 Setting from Standard to Full Speed. Would this help temps too BTW?
Ok no probsI might have found the settings you want me to change
I'll take a pic and post for you to see first and then you might give the go ahead
Ok no probs
Ok so where it says FIXED VOLTAGE type in 1.250v. Best to always start high and work down. Then save and exit.
