I'm assuming this comment is only directed at the 780i users...
Yep
Ps Dont put Crucial Ballistix ram in either, this will not work.
So....
So....
well.... before we go further here, make sure your not filling all the memory banks, this board doesnt like this, try slots 1 - 3 first, install the 602 bios which fixes a lot of issues and makes the board usable, do not play with the voltages at all leave them on auto, set the bus to linked and ram to linked, if all fails then this ram isnt going to work with this board.
Try this.... http://www.overclockers.co.uk/showproduct.php?prodid=MY-090-OC&groupid=701&catid=8&subcat=813
or this... http://www.overclockers.co.uk/showproduct.php?prodid=MY-105-OC&groupid=701&catid=8&subcat=813
Or better still get the 8500 versions, but im 100% sure this board is VERY picky with ram and doesnt like all 4 banks filled.
£180 Motherboard
£400 2x GTX
£170 Q6600
£170 1k power supply
£40 ram...
Personally I expect a high end mobo, especially with a MAINSTREAM chipset like the 680i or 780i to be able to work with bog standard PC2 4200 if I so wish, it should have MORE compatibility not less.
That info is real old and we all thought it was same Chipsets.
Right... What advantage does this give me ingame / windows ?Not really, you get what you pay for most times, the Chips may be far better (Micron) so more expensive.
I'm not fooled by price, my geil seems fine atm.Just because DDR2 is at an all time low dont be fooled into price.
Uhm, so? Your point? Buy ram when cheap? (offcourse my statement about not paying more than 40 is in regards to current ram prices)You would not be getting 2GB of any good Memory for £40 ever since the SDRAM days till recently.
It dont mean all expensive Memory is good but to buy parts at very high end of scale and buy cheap non branded Memory is just plain and simply stupid, keep that for peeps who want to upgrade their PC bought from the Purple Shirt Bridgade.
It is the same chipset!! I am not sure if you are agreeing or disagreeing.
OK So I've read the bit-tech.net preview and it reads the same as the anandtech one. It's the 680 chipset but with a new chip bolstered on that adds PCI-E 2.0 support. It's not native and all it does is add additional power requirements.
Judging from the heatsinks used and the tone of the author it also suggests they even haven't die shrinked the chipset as it runs hot.
nVidia is simply getting the most money from it's current designs. We should be seeing a brand new chipset (which we will probably see in Q2 anyway.. nVidia is launching hybrid SLI nForce 7 mobos) and new GPUs (whatever happened to dual-core GPUs?) instead of just slapping two 8800s on a single board.
It's all down to lack of competition from AMD. It's an improvement on NF6 yes, but it's only minor.
