Asus A8N-Sli Premium Mem Timing Input
Permabanned
7 Sep 2005
Cheshire
All,
I have just got an A8-Sli Premium mobo, and after readying the Corsair build report linked below (hope this isnt against regs):
http://sysbuild.corsairmemory.com/report.aspx?id=2&sid=13
I am struggling to input my individual timings for the memory.
I have different memory to the system build linked, with a CAS of 2-3-3-6, but my main problem is where to input these numbers into the mobo manual config as there are quite a few that look possibilities!
Could you identify in the BIOS which particular figures need changing to correctly setup the memory?!
GC
8 Nov 2005
As you look at the DRAM configuration screen:
Timing Mode: Manual
Memclock index value: 400 mhz
Cas latency (TCL) : 2
Min ras active time (TRAS) : 6
Ras to Cas delay (TRCD) : 3
Row precharge time (TRP) : 3
Row Cycle time (TRC) : 12
Row refresh cycle time (TRFC) :16
Read-to-write time (TRWT) : 2
Write recovery time (TWR) : 2
1T/2T memory timing : 1
S/W Dram over 4gb remapping : Disabled
H/W Dram over 4gb remapping : Disabled
7 Feb 2003
Hi GhettoChild,
If you have any problem with blue screen, relax some of the settings on your timings.
Memory sticks 1GB *2 or 512Mb *2?
Check on your memory voltage as well within the bios.
Simon
7 Feb 2003
That good I using 2x 1GB PC-4000 Crucial Ballistix which I need to run at cas 2.5 at 3200, as for voltage I are am using 2.7volts which is OK
Simon
