27 Jan 2006 at 12:09 #1 Sparky Sparky Soldato Joined 23 Nov 2004 Posts 9,586 Location UK Cannot get the onboard LAN to work no matter what i try.Anyone else got 1 of these and could help be greatly appreciated.
27 Jan 2006 at 12:16 #2 split split Soldato Joined 2 Nov 2002 Posts 3,534 Location Dorset CS||nuTs said: Cannot get the onboard LAN to work no matter what i try.Anyone else got 1 of these and could help be greatly appreciated. Click to expand... Which one? A8N-SLI Premium... Dual Gigabit LAN & AI NET2 I see two
27 Jan 2006 at 12:21 #3 Sparky Sparky Soldato OP Joined 23 Nov 2004 Posts 9,586 Location UK The top 1 of the 2.
27 Jan 2006 at 12:31 #4 split split Soldato Joined 2 Nov 2002 Posts 3,534 Location Dorset CS||nuTs said: The top 1 of the 2. Click to expand... OK now I need help. What one is that.... nForce4 built-in Gbit MAC with external Marvell PHY or MARVELL PCI Gbit LAN controller. The Nforce ones are known to loose their MAC address, but I don't know much about this board. Are you sure it's enabled in the BIOS? Disable it, and then re-enable etc and see if windows finds it. You have installed the drivers haven't you?
27 Jan 2006 at 12:37 #5 Sparky Sparky Soldato OP Joined 23 Nov 2004 Posts 9,586 Location UK Disabled it and enabled it and it is now seeking a address on the kids pc.Thanks for the help split.
