ASUS A8n32 Sli problem
8 Dec 2005
everything seems good with this board .. BUT .. on bootup i get this error, Keyboard/interface error , does anyone have any ideas before i ring for tech help ? thx for any help forwarded :)
Never had that problem with my a8n32. Dumb question I know but if its a USB keyboard is USB enabled in the bios (that is if you can get in the bios!)? Unplug everything apart from your pc apart from the keyboard, gpu and psu and see if that helps.
Have you tried another keyboard or tried the keyboard in another PC? Are the pins on the ps2 plug straight? I would probably suggest that the keyboard is faulty as the motherboard is detecting a fault with it.
Its not the keyboard , that works fine, seems to be the ps\2 socket, looks like i will have to uninstall all the components and check hardware connections :(
