thought so, thank youNo just the 8 pin the extra 4 pin is for extreme overclocking .
No its extra power if needed .What about the opposite...if one does hook the extra 4 pin up, is there any negative aspect if you aren't overclocking? I assume it would behave the same and just not use it but thought I would ask.
Just more cables to manage.What about the opposite...if one does hook the extra 4 pin up, is there any negative aspect if you aren't overclocking? I assume it would behave the same and just not use it but thought I would ask.
saw in the manual
ensure to connect the 8 pin and 4 pin if running in crossfire mode.
