Asus P5b Deluxe Sudden No Post Problem HELP :(
4 Aug 2005
Ok guys as i have a quiet day today at work i decided to bring my computer there and reformatt and have a general clean up! After tidying everything up and cleaning everything i re-built my setup, upon plugging everything in and pressing power my computer won't post :confused: ? everything fires up and i'm pretty sure i can hear my hard drive wiring away but i get nothing on the screen, i don't even get a power led on my case anymore yet i know power is there as everything is fireing up!
Things i've tried :
-clearing cmos (including removal of the battery)
-booting the computer on bench (with only cpu, ram, and gfx)
The only thing i have done differently is put a new heatsinc on! but i can't see this as a problem
can anyone help or have they experienced problems with p5b's not posting before? could it be that my computer doesn't like the works old rubbish crt monitor?
OP
4 Aug 2005
problem solved - if anyone comes across this problem in future try either reseating your heatsinc or in my case i had just over tightened my heatsinc so had to loosen it slightly! thanks anyways guys
