Evening all,
I upgraded my C2D E6200 setup today to an i5 Sandy Bridge, setup includes the following:
Mobo: Asus P8P67 Pro
CPU: i5 2500K
RAM: Corsair Vengeance (2x4GB)
CPU Cooler: Akasa Venom
I haven’t yet scouted the forum to see how others have setup their Venom, but I had to do so in such a way that the fan is mounted at the rear of the heatsink and is sucking through the heatsink and blowing it directly into my rear fan which is pushing it out of the case.
Mounting the fan at the front and pushing air into the heatsink wasn’t an option, it covered the RAM slots; likewise, mounting it in a position to push air into the heatsink and up into the PSU fan wasn’t an option because there wasn’t much space between the fan the and the graphics card.
At the moment the mobo is reporting a CPU temperature of 45-50c, while the Asus utility under windows is reporting 41c. These temperatures are under idle.
I’ve used the thermal compound provided with the Venom.
Do these temperatures seem a little too high for idle? If so, any advice on how to lower them? (Different cooler installation method, compound etc).
I’d like to OC the machine, but before I do that I’d like to get the temps down a little.
Thanks in advance,
Craig
CPU: i5 2500K
Thanks in advance,
Craig
