Codes are for:
B4 USB Hot plug. Take it you have removed all non essential usb devices - can cause failure to boot
B2 Legacy option rom initialisation. Try if you haven't resetting the bios and clear cmos
Nope, have you got your manual, its available on asus website here if you havent:
https://www.asus.com/uk/Motherboards/Z10PED8_WS/HelpDesk_Manual/
Yours, you have to remove a battery and move a jumper temporarily to clear cmos - easier to see in manual, just download the pdf and search for 'cmos'.
Have you cleared cmos and moved jumper back to its original position?
Give this a go, maybe something you haven't tried. There are a people a lot better than me at fault finding on here, hopefully someone else maybe able to help. I would start removing hardware, ram, disconnecting hd e.t.c to see if you can find a culprit, found a guide here:
http://www.tomshardware.co.uk/forum...roblems?_ga=1.120146952.1287745533.1492323624
