i've always installed over the top. never had a problem.
the over drive is buggy as when you oc, the min oc value is the actual oc value, may not matter.
To clarify.
No problem with 10.12![]()
Why do people perpetuate this urban myth of buggy ATI drivers? Most of us aren't remotely qualified or in possession of the technical know how to make such an assumption.
I always install straight over the top. Would rather do that than introduce third party software like Driver Sweeper. It's just introducing another potential point of failure in my opinion.
well, you don't need to be qualified to see software isn't acting robustly. it simply breaks, thus showing bugs. i kind of see what angle your trying to get at but most times the fault is due to the drivers exspecially when no third party software is used.
to clarify, i used a third party programmes to fix the problem.
When you installed your new drivers did you remove your old drivers first?, if not that will be you problem.
so remove your new drivers now and start from fresh![]()
