I would check to see if your CPU is stable and running at the rated speed. It's also possible that with the bigger Graphics cards the motherboard needs more QPI/PCIE and IOH volts. Usually 5970's with i7 CPU's at stock speeds would get around 20000, and if your memory has scaled its speed back then that could explain the score of ~18000
EDIT just checked my screenshots and my CPU scored 7350 in 3Dmark06, and that dosn't include the fact that it bumps up the other two scores aswell. It sounds like you CPU may have reset itself back to stock.
