I was/am looking at mini-itx motherboards with temp sensor connectors, mainly due to fan control. I know for example that Asus armoury crate (although I personally loathe it) has the ability to set fan curves in relation to temp sensor readings.
My confusion about using a valve connector as a drain port was more with what should be connected to it, but i'm guessing just a bit of hose connected to a male connector and then connect this to the valve connector when wanting to drain the loop?
Thanks again for replies and for continual assistance.
That's a scary picture pre btw of a green stained block. I will try to rinse thoroughly after cleaning my rads.
Cheers for answering my question regarding ptfe tape, although from your answer I now want to ask - Should washers on connectors be changed at regular intervals etc?
With regard to the motherboard/cpu and ram I am starting to realise that there is not much difference in buying new mid-range than older used mid-range. I shall follow a few items that I have already bookmarked on eBay for next week but also price up a few new bundles. I was tempted by the 7500f in MM Sales but could not find many reasonably priced mini-itx motherboards to fit it to.
I use asus AI suite instead of
Armoury crate
It can set curves based on coolant temp
I wouldn't even install Armoury crate but it's only
Option to control the oled screen on my motherboard
Yes basically unscrew the g 1/4 blank off
The end of your ball valve
Screw in a male fitting with some hose on it
ideally with the pc on a desk,table,worktop etc
And a long enough bit of hose to reach whatever you're
Draining the coolant into
So gravity helps you and you have both hands free
Washers/0 rings on fittings
Those tend to last a very long time
Unless you cause any physical damage to them
Can't say i have ever replaced one
