Azureus problem - torrents stop at 99%
24 Dec 2004
Knowle, Solihull, UK
Hi
I haven't had any problem at all with Azureus for a long time but recently torrents stop at 99%
I don't think they're bad torrents as other people download them without a problem and I have plenty of seeds connected
Does anyone have any ideas? It's been at it's current percentage for over 24 hours now
I do have a NAT problem with my current router but this has never caused a problem before
Here's a screenshot of my Azurues screen
Many thanks :)
Stop and exit Azereus then restart. Azereus should recheck your files.
Also have you tried playing the files even thought there only showing as 99%?
Thanks for the quick reply :)
That sorted it - they've started downloading again
I did try playing them (even though they're at 99%) and they worked fine - I skipped through the vid and let the last 20 seconds or so play just to make sure
Cheers :)
I think this can be caused by thumb files, if the seeded file has a thumb file in the folder it is counted as part of the 100% but the program will not download them, if it gets to 99% and the files work i would guess it is the thumb that is the last 1%.
And of course things often do slow down at 99.x% because you're down to asking certain peers for a few specific pieces rather than having loads of pieces come from all over the place. 24hrs does seem way too extreme for that, though! :)
Thanks for your reply - it did have a preview as a matter of fact
Re-starting Azureus caused the torrents to start downloading again though so they did get to 100% in the end!
