Ballistix 5300C3/6400C4/8500C5 speed binned chips or the same?
Maybe the voltage was what was causing the instability on the OC then? So if I were to tweak with the FSB and say get the RAM running over 740, say 800 or more, would 4,4,4,12 still be suitable?
I'm not sure if 1.9v would have affected stability at 740mhz 5-5-5-15. I would expect the Ballistix to handle those settings, tho you do have 4gb and that is harder to get stable.
Tho 3.3ghz is a damn good AMD clock and may be the limit of the chip.
But certainly set the memory to 4-4-4-12 if aiming for 800mhz.
Hi Cob,
Yes, ran alll night at 3.33Ghz and RAM at 4,3,3,10. Thanks for all your help.
You're right, the CPU doesnt want to go anymore! I know someone thats got one of these to 3.4Ghz, but I guess it depends on your particular setup.
Thanks again.
