I'll start from scratch, just in case anything I mention is relevant to the problem.
Graphic card is an AGP Powercolor ATI 9800SE, 128mb RAM. This was bought by somebody for their machine, and I am to install it.
Machine has 512mb RAM, Pentium 4 2.4GHz, 160gb HD, CD-RW, DVD-RW, using onboard sound, was using onboard VGA before installing graphic card. Runs Windows XP SP2, with latest updates.
I download drivers from ATI's website - Catalyst 6.8.
Install graphic card, with floppy power connector connection. Machine boots up fine, Windows picks up the new card. I do not install the card as a "standard VGA adaptor" or whatever Windows calls unrecognised graphic cards.
I run Catalyst installation. I think it tries to install drivers, then I'm left at the desktop waiting for some kind of "drivers are installed" message or something...nothing for 2-3 minutes, no HD activity - so I reboot, assuming all is installed.
Reboot...I think Windows picks up the card just fine. Thinking all is well, I run Command and Conquer Generals - a few seconds into the menu (just as I'm about to move mouse to change settings), I get a blue screen. Just a blue screen, not a BSOD - no writing, nothing.
Reboot machine, I try Age of Empires 3 - again, at the menu, it simply gives me the blue screen.
Assuming the drivers weren't installed right (I was dubious), I uninstall them, run Driver Cleaner. I try to install the ones from CD, but again they hang when installing the driver. I try to install the drivers from Device Manager - but it gave me a "the parameter is incorrect" message, after copying the files over.
I'm getting fedup by this time, and hit Google. After about ten minutes of scuffling around in Google's search results, I find somewhere that sometimes the permissions to the ATI key aren't set properly. I check this and, as the poster said, I needed to set this get to Full Access.
I uninstall the old drivers, run Drivercleaner. Reboot, run Catalst 6.8 setup. This time it installs drivers just fine, and even installs the ATI panel (?) - something I hadn't seen it do before. I get a message following the lines of "all is installed, reboot to complete" - so I reboot.
So far, so good - run AOE3 again! I get that bloody blue screen - nothing on the blue screen, just a blue screen! Same with C&C, too!
After another Google, somewhere said to try disabling DEP, but editting the boot.ini file. I do this, but nothing changes.
At this point, I am well and truly baffled. I am in two minds to tell him to take the ATI card back to the shop for a refund, and go elsewhere and buy a Geforce one.
I once contemplated buying an ATI card - but this experience has put me clean off. Ok, it might be just a one-off. But I'm used to things working pretty much first time round with Nvidia cards, no tweaking, editting files or messing about in the registry.
Anyway - I would truly appreciate any advice or pointers with this card. I am very reluctant to reinstall XP - I don't see why I should, just to accomodate for ATI's drivers/software (whatever the problem is).
They might have taken it back, loaded to Windows, saw it looked ok and thought oh well, back in the box it goes.
