1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Benefits of using two NIC
Discussion in 'Networks & Internet Connectivity' started by Reeferjon, 24 May 2006.
  1. Reeferjon
    Q.
    What would be the benefit in terms of overall network speed if I were to add an extra NIC to my simple file sharing machine and fed that also to my switch (guess I would need a cros-over for that).
    The machine is XP pro running RAID 1 and performs no other function than to share files.
    Thanks.
    John.
  2. growse
    If both net cards are same make and have drivers that support teaming and/or bonding, then you can use teaming/bonding for resiliancy/speed.
    You might need a switch that supports it, and you'll only see a benefit in speed if you're maxed out on your current connection, and the resiliancy benefit comes if you absolutely need 24/7.
    In short, unless you know you need it, you probably don't.
  3. Ricochet J
    Capodecina
    It'll require more CPU power from your Switch.
    Why not just get one GigaNIC with Gigaspeeds?
  4. Reeferjon
    Yeh I see your point two NIC is going to be a pain...
    If I went to GigaNIC would that not mean I would need to swap my switch out for a GigaNIC, (then cables and the other NIC's eventualy)........
    I suppose that if the Switch were Giga then the data rate to the switch would be able to cope with say 4 (100Mhz) connections that were running at say 50%
    John.
  5. hybrid
    Wise Guy
    If this is for a home network then i dont see the point tbh.
    Maybe you could get a Gbit NIC but then the switch would have to be Gbit too.
