BENQ G2420HDBL 24" LED MONITOR ONLY £149.99
17 Oct 2002
Stoke
First we had the deal on the standard version and now we've gone one better. The LED version offers improved colours and darker blacks for improved image accuracy. At only £149.99, in my opinion it's an absolutely bargain with DVI connectivity as well.
BenQ G2420HDBL 24" Widescreen LED Monitor @ £149.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
- Warranty: 3 Years On-Site
Only £149.99 inc VAT.
ORDER NOW
how on earth is a 24" LED so cheap...what's the catch?
its only LED backlit, from what I can find on google they are great monitors for the price. not going to set the world on fire but do the job
hmm 2 of these or 1 Samsung SM2433BW.
These look like a gr8 offer, cant believe there only £150 seems to good to be true
Are they side lit? does that make difference if they where?
Looks a good price to me. It looks like 1080 is the the way things are going instead of 1200
I'd go for 2 of these. :D
I've seen the standard version in the flesh and its gives a real nice picture, so this should be better.
All these great offers!!!! Looks like my flexible friend may soon become brittle. :D
yeah found a spare dvi so 2 of these it is :D
I've got a very nice Samsung 24" LCD. I think I'll think about changing it when there is a 26-28" LED for a good price. No rush:cool:
We will be holding the price. :)
drop it, and hack an hdmi port onto it and I'll buy 3 ;) oh, and throw in the active DP adaptor :)
hmmm, maybe you actually should do something like that, make bundles of 3 monitors that would work with eyefinity (either with adaptor or inbuilt dp) with a little discount :D
