BeQuiet Dark Power Pro '80 Plus Gold' PSU - Lowest UK price!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
The excellent 80 Plus Gold, high efficiency PSU from BeQuiet is now at a great low price.!!!
BeQuiet Dark Power Pro P9 850W '80 Plus Gold' Modular Power Supply @ £136.98 inc VAT
The DARK POWER PRO series is intended for enthusiastic PC users who prefer very high powered systems and who expect premium performance.
The power supplies in the DARK POWER PRO series work with the latest technology to achieve extreme efficiency (80PLUS Gold certification) and reliability. The DARK POWER PRO is also one of the quietest power supplies in its class: The Ultra Silent concept works with the be quiet! SilentWings fan, developed by the company for optimised air flow control and a special decoupling of the fan for whisper-quiet running.
In the DARK POWER PRO, one receives a solution that is convincing both from a technical and optical standpoint: The modular cable management includes a 115cm removable cable to provide maximum flexibility and convenience. The power supply offers a variety of connection options - such as for external fans - guaranteeing that even the highest-powered components will enjoy top compatibility, a reliable power supply and optimal cooling.
- High resolution gaming and multimedia
- Server-based multi-CPU systems
- 3D CAD graphics, photo editing and video editing software
- The RPMs on the fan are automatically governed based on the temperature
- Optimised air flow leads to a reduction of the fan speed in the entire working range, allowing even quieter running
- Special decoupling of the fan from the case reduces vibration to a minimum - for greater quiet in the PC
- The cable management system offers up to 32 connectors and is designed to be compatible with older components as well as those not yet designed
- Modular cable management: The removable cable bundles make it easier to install components, provide a more orderly structure and promote better air circulation within the case
Was £159.99 Inc. VAT
Only £136.98 inc VAT.
ORDER NOW
you migt want to change the thread title. the bequiet dark rock pro is a CPU cooler ;)
(although the "80+ gold PSU" that came after it was a bit of a giveaway)
