Caporegime
http://www.coolermaster.co.uk/upload/download/519/files/690 II nvidia product sheet-1119.pdf
Says bottom mounted power supply supports 190mm.
The XFX is,
Physical
PSU Dimension (cm):19.0 x 15.0 x 8.6
So yeah, it will.
The XFX is,
Physical
So yeah, it will.
You get what you paid for, I suppose. The Seasonics (XFX is the same unit internally) are the gold standards (no pun) in PSUs. Particularly their Platinum series. However I'm sure you'll be fine with the OCZ.
