Hi , asking for a mate as i havent had air coolers for some time,what is the best air cooler for socket 1366 at present as he is building a system and would like to give it an overclock
Though not air cooling but as easy if not easyier to fit then a big heatsink is the H50 which is nice.
Yeah he has looked at the H50 and the Prolimatech Megahalems , the only thing puts him off a big cooler is strain to the Motherboard ?maybe ??
Does the H50 come with a fan and if it does is it quiet, also i think he read that it gives similar temps to the Prolimatech Megahalems is that about right?
Here you go Prolimatech Megahalems
Most of the mounts are pretty well thought out, so I wouldn't worry about the motherboard.
The only one that hasn't been mentioned so far and beats pretty much anything air wise is the Thermalright IFX-14, due to its huge surface area. I've just ordered one so hopefully it will arrive today or tomorrow. The only issues with it are the price and size.
The Corsair H50 is good if you have the space to mount the rad near the CPU, if not and you don't have space for the IFX-14, the Prolimatech Megahalems would be what I'd go for.
