I use the Scythe Miné Quiet Heatpipe CPU Cooler http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-SY&tool=3 it's not the cheapest cooler but I certainly think it's one of the quietest, I've used around 12 different socket 775 coolers and this has to be one of the best I've owned, tbh as pretty much all the C2D chips run at a low temp so any cooler will be fine, I've even heard of people getting good o/c's using the stock cooler but I'm not a fan of that as it get's a little noisey on load.
Ac Freezer 7 pro, running half speed (1200rpms) idle 28-31 (accordig to BIOS), actual cores are about 40-41 using core-temp, and the Freezers silent, never bothered checking my load temps as its running fine, and temps are low at idle.
