Looking to setup a triple monitor setup via display port for the likes of racing sims, Euro truck 2 etc.,
Obviously with getting 3 the budget is hit so looking at around £150ish per monitor.......would like as many of the bells and whistles as possible but I know this is compromised by the low budget now. Size ideally 27+.....the bigger the better!! Key spec I was looking for before deciding on the 3xmonitors was 1440p, 144mhz........
Gfx card is a 5700xt red devil - room is dark.......
Really appreciate any advice as I'm feeling a bit light-headed with the amount of options available!!
