Best Budget Water Case?
25 Jun 2008
Anyone got any ideas for a decent size but not stupid money case that would house a 2 x 120 rad?
Would love somthing like the corsair but £200 isn't going to happen :rolleyes:
i dont mind if I have to mod it, ideally looking to roof mount the rad but cant find many cases with any clearance above the motherboard tray :mad:
lancool k62 is quite a good case for the money, dont know about the distance over the mobo though, that was my issue
I didn't think there'd be enough space in that. Although yeah, brilliant case otherwise. I just bought one after much browsing and it came up top on loads of reviews.
The Antec 300 is nowhere near big enough for a proper watercooled system, no room for rads.
Im going watercooled now and ive had to change from my Antec 300 for it.
:D
Whats wrong with a bit of modding ;) Could easily watercool in an antec 300.
Can easily get a 120.2 in an Antec P180/P182, and you can buy them for £60 - £70 now. They're hard to find as they're old stock, but they are about and they remain the most attractive case on the market in my opinion. I'll probably never get rid of mine.
I am right now, in fact :)
Granted I've only got a 120.1 and a 120.2 rad in there, but it's more than enough for CPU :)
My suggestion would be to look at NZXT or getting a 2nd hand case
Ive seen much smaller cases watercool perfectly well (i had a v350), i rekon the antec would be a decent project. But i hate the looks :(
