Best case for cooling under £60
20 Nov 2012
Need recommendations on which case is the best at fan cooling for under or around the £60 mark. Will be running a 3570k overclocked so need to keep things as cool as poss.
Would like it windowed too.
So far thinking:
Cm HAF 912 plus
Zalman z11
Cm 690 II
Gigabyte GZ G2
Any input or recommendations?
Thanks
1 Apr 2009
Corsair Carbide 300R?
Z9+? It's loaded with fans, and cheap.
People have been using the 690II and the 912 for donkey's without issue. Any decent case will do OK tbh.
27 May 2011
London
So far thinking:
Cm HAF 912 plus
Zalman z11
Cm 690 II
Gigabyte GZ G2
Thanks
what about
YOUR BASKET
1 x Thermaltake Commander Snow Edition Midi Tower Case - Black/White £46.99
Total : £57.49 (includes shipping : £8.75).
26 May 2012
YOUR BASKET
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £46.98
Total : £58.08 (includes shipping : £9.25).
best value entry level case imo.
4 fans, fan controller, temp reader as standard.
only thing is that it doesnt have usb 3 ports out at the front.
of course, if you dont need to buy from ocuk, a quick google for the z9-u3 (the version that has usb 3 ports) should show you which etailer sells them.
OP
20 Nov 2012
I like the thermaltake but only comes with one fan.
Thinking now z9 or paying a bit more for the 690II
Hmmm... decisions decisions
27 May 2011
London
YOUR BASKET
good shout, I would prolly go with that.
10 Jul 2008
I used the Antec 300 for a recent build for a mate, and I have to say I'm really impressed with it for £44.99. Build quality is good and it cools well.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-101-AN
The spare cash left over from £60 could buy some nice fans.
But since your budget is more, you could look at someof the coolermaster cases. EDIT: Maybe not, most good ones appear to be over £60 these days.
OP
20 Nov 2012
Funnily enough I went with the z11. Want to run an est t40 cooler and thought the z9 would be too narrow.
Thanks for your help.
OP
20 Nov 2012
Also ordered a z77 extreme4 and 8gb of corsair vengeance ram.
Plus a 60gb Kingston ssd for now :)
