Best cooler for an unlocked PII X2 550
7 Mar 2005
As title really. Just want some advice on coolers for my cpu. I currently have an Artic Cooler Freezer 7 Pro thats several years old and the fan doesn't attach to well. My case is a CM Dominator II lite. The ram is corasir DHX and at the moment two slots are blocked by the fan. It would be useful if I could get access to the slots again but cooloing i smore important.
An Akasa Venom or Titan Fenrir will probably be plenty good enough to cool an unlocked 550. :)
To get noticeably better you have to spend over £50.
Thanks for the suggestions. I've had a quick look through reviews and all seem good. I'll do a more detailed read tomorrow.
I did notice the Thermaltake Frio getting good scores in those reviews, although it may be a little noisy.
