Best fan for i7 that isn't too tall.
1 Feb 2004
Hackney
Hi all - just built a new i7 920 rig and installed a Prolimatech Megahalem.
Sadly I didn't check it with my case and it doesn't fit. My case is a very old but lovely ATC 201 and the top of the cooler is probably about 2 cm too tall.
Was wondering if anyone had run into this before and could recommend a cooler that would fit a slightly skinnier case and still performs really well for a bit of ocing. Perhaps a top down one rather that the side on variety of the megahelm?
cheers
should totally just chop a chunk out of your case!
Look how pretty this case is! I would rather use windows me than change this baby.
Hi I have an ATC 201 case too and am looking for a cooler to fit in it for a new Q9550, I currently have an AC7Pro which is 126.5mm tall.
I have measured inside the case and there is pretty much exactly 30mm more space, which means that a cooler 156mm or less should fit?
Apparently a Titan Fenrir will therefore fit, and a Tuniq Tower 120 Extreme (150mm) should definately fit. I was considering the H50 but wouldnt be able to mount the radiator in the top front bays as I have a long DVD drive.
Would it matter if the Fenrir was *just* touching the inside of the case wall (which is painted aluminium)?
