Static pressure tells as much about fan's real world performance as sound level available from car's engine with gear at neutral tells about car's actual speed:
https://martinsliquidlab.wordpress....w-specs-are-poor-measures-of-fan-performance/
Yes, you've posted that before in similar discussions, as if it is somehow the be-all and end-all of any substantiation to your opinions...
As for your ridiculous analogy, you clearly haven't read the article yourself - To quote the author himself, "
This just means the two spec we often use for comparison are an incomplete picture and should not be relied upon 100%". However he does also state that
most fans do have a linear curve, which is why the geeky academic numeric duelling above can take place.
See here for further details:
http://www.arx-group.com/pq.html
Or to quote Nidec themselves: "Fan air volume-static pressure characteristic diagram (P-Q curve) is a curve that shows the relationship between the air volume and the static pressure resulting from loss
due to the pressure applied to the inlet and the outlet of the fan."
But to use your car analogy - SP is the tyre grip compared to the AF being torque. No matter how much torque you have, you can't put it down on the road without sufficient grip.
So as I have said earlier in this thread, it depends on several other factors in addition to the fan specs... which is why I generally advocate a 'suck it and see' approach rather than trying to figure out the various numeric quantities for the numerous different factors which also aren't supplied by the manufacturers. The throwing around of numbers above is purely academic duelling, especially when the real world results will be so variable and even highly subjective.
End of the day, no matter what your PQ-Curve is, more static pressure still means more of its airflow actually making it through the restrictions. Same as we know full well the Mfr's noise isn't real world noise, but that restrictions of any kind
will make that fan louder.
You will likely need to alter the RPM for your particular fan in order to get optimum performance, because (surprise surprise) not every fan performs best at the same RPM anyway... and in your link, for the most part, the higher SP fan
does still perform better. All other things being equal, more fans spinning slower usually cool better than a few fans spinning faster, for these very reasons.
