If you're cleaning the outside of a case, then go for a slightly damp cloth, just make sure it is only slightly damp, and its not going to drip inside! Remove any pannels you can and clean them seperately. When cleaning any bits that can't be removed, be safe and do it when your computer is turned off, or be extra safe and strip everything out of the case first.
If its just dusty then you can't beat a feather duster! Although people may get scared if you go for the maids outfit too...
PK!
