Best pin / password app for Samsung mobile ?
11 Oct 2005
Derbyshire
Hi just upgraded from an iPhone 6s to a Samsung Galaxy 9 Plus.
On my iPhone I used to use the free version of ikeeper . Which was okay . But it does not transfer anything over to the Samsung version of ikeeper unless I pay quite a bi .
I'm new to Android and Samsung is there a good free password manager app, that will do the job for me please
For storing things like work safes codes.
Passwords for apps and websites
thank you
Sorted it thanks
It's just for keeping things like safe codes. Door lock codes etc. credit and debit card pins safe.
Samsung notes. Works fine with the notes lock facility.
Sorted it thanks
There are also other wasy you might want to take a look at these vids.
Enchance yoru samsung security
https://www.youtube.com/watch?v=XZVQuBdxlJU
samsungs secure folder
https://www.youtube.com/watch?v=JHPyzVPuTSA
Samsung's Secret Security Feature for your Galaxy Smartphone
https://www.youtube.com/watch?v=-OvObtNMexA
Most probably better than just using the note feature especially for what your using it for.
Hope it helps
