Best place to buy Car Care products?
6 Dec 2005
Hi every1,
I was just wondering if nay 1 recomends anywere to buy car care equipment from, was looking for a couple of microfibre cloths, meguiars quick clay kit and some meguiars nxt tech spray wax?
What are the best microfibre cloths to get? Also whats best for drying the car with, will the microfibre cloths do the job?
Cheers
ardy89 said:
Hi every1,
Cheers
Halfords are 3 for 2 at the moment, but their quick clay kit is expensive, have found it half the price online, but delivery is £6 odd so not worth it with halfords having the offer atm.
Scratch X is rubbish from Meguiars though and other people have recommended Sonus drying cloths.
Any of your local motorfactors sell the stuff. The one near me holds a huge range of Meguires, Autoglym and others on the shelf.
Best thing I found for applying the polish (which I just done this morning) was a sponge wrapped in microfibre cloth thing (cant remember the make off hand) which was really good at shifting some of the bugs and tart too during the process. Also recommend the applicator pads from Meguires, they make your polish go a whole lot further I found.
Dont bother with the water magnet towel though, waste of money IMO, an old fashioned shammy was far more effective.
Right well I have now purchased the wax and the clay kit so all I need is some kind of applicator/remover for the wax/polish and also a drying device, recomendations?
My post above?? :D
LOL Sorry Buddy, I did read it its just wanted second opinion, your post has been recognized though. I shall be buying some microfibre cloths tomorow :)
