1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. We recommend you enable 2FA on your OcUK forum account. Please see the thread here
    Dismiss Notice
Best simple car wax?
Discussion in 'Motors' started by Dyson, 12 Aug 2021.
  1. inflames
    Wise Guy
    What are you after high gloss? Or lasting protection? Or even the middle ground. Also how much you want to spend?
    My favourite wax at the minute is wax planet’s white noise, easily applied and buffed off leaves the paint work with a nice shinny wet look. Gives about 3 months, worth of protection.
    I also use Fuso coat over the winter months one of the better ones for longer protection, it is not the best for gloss but that is the pay off for the level of protection.
    Some of the new turtle wax, waxes are suppose to be good and have heard very good things about double speed wax.
  2. Dyson
    More options than I was expecting, thank you everyone
    I'm looking for some protection, but more a deep gloss finish. Budget? I guess up to £25
  3. Kei
    Mobster
    Bilt Hamber Double speed or Collinite 476S would be my choice in that price bracket.
  4. dave28
    Wise Guy
    that is one issue with wax that is very easy to use and easy to wipe off, it usually suffers in other areas like protection, how long it lasts and how well it holds up to car washing.
  5. adam cool dude
    Capodecina
    Colinite 476s will easily last 6 months. Colinite 476s is to wax what water is to quench your thirst. No nonsense and does the job.
  6. dLockers
    Well this was an inconclusive thread :D
    I'd get some micro fibre pads, some AutoGlym Ultra Deep Shine, and then some AquaWax for every subsequent wash. Least faff of all the options so far IMO.
  7. dave28
    Wise Guy
    that is tough to wipe off in my experience but i may have been leaving it on too long yes lasts ages and ages.
    i way prefer the jelly like version of that called collinite 845 because i found it easier to use and still half decent.
    i switched to sealents though, i must have 10+ types of sealent and hybrids.
  8. chroniclard
    Capodecina
    476 is only tough to remove if you put too much on! (Like I did, took hours:cry:)
    I like SONAX Xtreme Brilliant Shine Detailer if looking for a quick top up/shine.
  9. CaptainRAVE
    Man of Honour
    Aqua wax or Sonax are your quickest and easiest to apply waxes.
  10. Conscript
    Sgarrista
    Added bonus, its a physical workout to remove. Dare you to do the wax the whole car before buffing, rather than working on a panel at a time. You'll have arms like Popeye in no time.
  11. Doobedoo
    Mobster
    Not true unless you have done something wrong and applied too much.
    I use a moist foam on pad and have done for years easy on, easy off. Twice a year no faff just good product that does what’s it’s supposed too.
  12. adam cool dude
    Capodecina
    I did that once. Ended up buffing it off with a DA.
  13. Howard
    Capodecina
    This is why I am now sold on spray ceramic sealants. 476S is good, but the application process was a faff. There was an extremely fine line between the right amount applied and the right cure time, and it becoming an absolute ballache to remove. It annoyed me.
  14. DXP55
    I use Colinite 845 which is a liquid -easy on easy off - My Focus is also black and it shines up really well -Took it to garage for service and told them not to wash it but a lad did hose it down and couldn't believe how the water beaded and ran off. After a good wash it looks just like it's just been polished.
    I did use the Colinite wax but found it hard to remove but that's probably my old arthritic arms.
  15. dave28
    Wise Guy
    no its not your arms, it goes off like concrete lol. you need to buff it off not long after putting it on. Another one that is superb but a swine to get off is bouncers vanilla ice but its expensive compared to colinite. Dodo juice hard candy is quite good as an alternative.
    as you probably discovered though the 845 is easier than hard waxes and a great choice
  16. Doobedoo
    Mobster
    It’s very easy to use, if your finding it hard then your doing something wrong. I’ve been using it for years and still have 3/4 of a tin left.
  17. SkodaMart
    Mobster
    This. This is what I use.
    Gives good protection (water still beading months later) and very easy to apply.
  18. mikehhhhhhh
    Hitman
    I've never been a big fan of Wax.
    It looks great on a dark car with excellent paint and lines to show off, but otherwise I find it actively attracts stuff like Pollen and doesn't protect as well as a good sealant.
    Until recently, I have used Zaino Z2P for probably 15 years as it's easy to apply and remove whatever the weather and leaves a nice slick, well protected finish. I just find a good sealant easier to work with and longer lasting.
    That said, for sheer ease of application the van gets Autogylms Polar Blast Seal via a foam lance and it's pretty decent. If you don't have a foam lance, I believe Aquawax is very similar.
  19. Kenai
    Capodecina
    Polar Blast is a prewash foam, you're talking about Polar Seal I think.
  20. mikehhhhhhh
    Hitman
    You're right, it's Polar Seal I was thinking about.
