xonar dx with dolby headphone on DH-2 setting set to either headphone or hifi on game menu is mint, i use HD600 senns, also i add a slight lift 30,60hz for bass impact without distortion.
Sorry to interject, but I have some stereo cans and a Xonar DG.
What are the best settings for use on BC2?
Heaphone settings in game, plus Dolby Headphone enabled on the sound card?
You don't need to force the .ini file. It will automatically set the number of speakers to match the setting for Windows.
That is odd as it was set to Home Cinema but had 0 in the .ini file.
Argh... everyone WAIT just a min.
The setting in the *.ini file does indeed set the number of speakers, however 0 is the default auto-detect setting and I suggest that you leave it that way! The game will then detect the number of speakers it's outputting to based on the windows speaker configuration settings.
Yes but as I said, if you're using headphones with Dolby Headphones, surely the game is NOT going to pick up a 5.1 home cinema system?
...and presumably it's going to benefit most from that being sent to the sound card otherwise it will just get stereo, and clearly surround sound can't do much with that except stereo trickey.
