Best usb c charging cable?
18 Jun 2018
Isle of Wight
Any recommendations for a cable for charging an lg g6?
Personally i suspect my wife's phone is just very well used and the charging socket is a bit loose. Combined with other things. However I've been tasked to find a good quality cable. The same ones seem to work ok on my phone but for some peace can i have some recommendations?
Never had any issues with a £1 cable. Why not change the charging port you can pick one up for £1. If you need help getting the case/frame apart I'll try and help.
