Is there a setting that puts this on in game?I'd also try MSI Afterburner and have the stats on screen whilst playing my favourite game. You'll soon see if your CPU is running flat out.
Cheers, i will try this. The clocks are set to 1700 and im getting 1359 max clock when playing CS:GO, or is just cs:go thats not demanding enough for the clock to go higher? GPU-z says i got 100% gpu usage.CPU is bottlenecking your system.
I'd run real temp and msi ab and monitor the usage. You'll probably find your CPU at 100% and the gpu at half that. If you don't have an overclock on the cpu, I'd suggest applying one. The alternative is to upgrade to an i7 as the old 4c/4t cpus are appearing to be somewhat dated now.
Yes there should be an on screen display setting in the monitoring section.Is there a setting that puts this on in game?
if you up your resolution in game and fps don't drop your gpu is bottleneckedSo I’ve just bought a reference 5700xt and I’m running it with a stock 4690k, is there a good/preferred way of checking if the card is being bottlenecked?
cheers
@Doilus: I have questions!
I'm considering putting a RX 5700 in to my i5 4670K system which sounds similar to your starting point.
Did you get a worthwhile improvement when running the 5700 with your original CPU?
Any power / PSU problems?
Was a PCIe4 card in a (presumably) PCIe3 motherboard an issue?
All good in the end? Thanks
So I came from a r9 280x and the 4690k was at stock, I wasn’t getting as high FPS as I thought so I did overclock the cpu, got it stable at 4.5 ghz fairly easy. FPS is a lot higher with these settings but I’m still unsure how bad the bottleneck is, I do get 100% gpu usage in benchmarks and the cpu is staying pretty. I will say though the reference 5700 is no where near as loud as people were saying online... my 280x under stress was much louder.
Everything is running fine but I need to look further into finding a definitive way of finding how much the bottleneck is.
