Best way to clean Nike Air Trainers?
if theyre white leather, clean the outside of them using cif cream that comes in the yellow bottle.
for the inside a few sprays of febreeze, let it dry, then re apply a few more times.
Wipe the outside with a damp cloth, you can buy special stuff for suede if you want to clean that as well. For the inside you could try moth balls, if not you could try the shoe spray from tesco for a week.
If you dont want to do the above your only option is washer machine on a low heat then dry in an airing cupboard. Do not put them on a radiator.
I've started buying odour eater insoles for my new shoes now - helps them last a bit longer, I find. Sorry it doesn't help your immediate problem though. Bit of spit and polish :)
