What I have found easiest is to wedge the edge of the shovel under the compacted snow and lever it. Usually it will break into reasonably large chunks that you can then pick up and throw away.
doesnt work when the surface isnt smooth, the surface is like really stoney soily stuff
start car. allow engine to warm. turn heaters upto max. Improvise a duct system that channels the hot air from the heaters to just in front of each wheel.
Not only clears the drive but also clears wherever you drive*.
*max reccomended speed of .1mph to allow time for ice to actually melt
haha the sad thing is my heater matrix is gunked up so it only blows out mildy warm air at the best of times, meant to flush it through but forgot when changing the coolant
I managed to clear some of it by hitting it with a pick axe but its taking forever and I suspect when I go out again tommorrow it will be back nearly the same again
should clear over the weekend though.. right??
