– This Warranty will not cover:
b) Repair or replacement required due to a gradual reduction in the operating performance of a covered part, commensurate with its age or mileage. (Please refer to Wear and Tear Exclusions)
- The following are not covered by the BMW Approved Used Car Warranty: brake and clutch facings, discs and drums, bulbs (except Xenon), fuses, channels and guides, weather strips and seals, handles, hinges and check straps, trim upholstery and cosmetic finishes, wheels and tyres, wiper blades and arms, glass, auxiliary drive belts, coolant and fuel hoses, the cleaning and adjustment of any component and all service items or items that will require periodic replacement. Corrosion is also not covered by the warranty.
Nottingham branchThe one in Leicester? My brother used them, did a good job
Just get it done elsewhere if its noticeably cheaperMy 128ti is in for a service. They say the front breaks need doing and reckon it's 300 including vat and fitting, seems pretty steep to me.
66% of the BMW price, not a bad saving!Yeah going to check with my local garage.
I've only done just over 17k miles.
Edit
200 for BMW pads, 150 for after market at my local place.
Edit
This sounds very expensive...I've just done the front discs and pads on my F80 M3 and the pads were cheaper than that (total parts cost inc. delivery was <£600). FWIW my brakes did 88k miles before they needed doing, and I changed them when the wear indicators came on (BMW noted I should consider changing the pads for the last two services!).Yeah going to check with my local garage.
Edit
My 4 series had them replaced just under 28kThanks I will do that then. It does seem a little odd they need replacing after only 17k miles regardless of my driving habits.
Edit
Just checked the video they send and they reckon 3mm.
Exactly same as my mini. Mine were fully worn. For some reason sensor didn't indicate.My 4 series had them replaced just under 28k
But the bmw approved used warranty says
so £200 seems a good result
do you expect a manufacturer to be perpetually responsible through multiple owners for parts that don't last as long as might have been expected
