its proving difficult to find that part though you know
presumably any light that indicates it is not up to temp, and is heating, was still coming on ? which indicates thermostat has not failed completely.
In the absence of a meter, I guess you dont have the means to temporarily wire a light bulb into where the element is, which would show if oven is turning element on
(would need crocodile clips)
I've used ransomspares.co.uk in the past
What's the model number of the oven? Surely some about, unless an ancient oven.
where do u reckon the thermostat would be
I think the grill actually works and the top/bottom heating element
its just the oven being on 3D /eco hot air modes it just don't get hot enough
Id just go ahead and swap the element. Tripping the RCD is a high probability of an element issue.
I wouldn’t turn the oven off at the isolator as soon as you have finished with it. They require cooling time (you’ll note the fans still run after it’s been turned off), mostly for the PCB/control circuits.
Once they are done you can turn it off that said you’ll be saving about 3p (perhaps 6p with all the recent rises!) in electric a year by doing so. EU regs on electronics means standby power on these things is next to nothing.
It's from 2015 the model it is Bosch HGB634BB1B/15
pretty decent oven so far apart from this issue
so here is the official technical information sheet/spare parts and yep just my luck no bleeding mention of that heating element that I actually need
smh
https://www.bosch-home.co.uk/suppor...spareparts/Togglebox=tb0199/Togglebox=tb0905/
Nice one
Once you have done it once, the next time is far easier. It's not that difficult of a job but most people just don't know where to start, give up and get a new one.
I did a washing machine element for the first time a few months ago, took a lot of swearing to get it out because it was all gummed up with limescale and soap but I'll know what to expect next time round.
Things like heating elements are always a matter of 'when' rather than if.
