I suck the oil out of the dipstick holeso true ... you must have a high ape index , or a high car, to do it w/o jacking ... even with dedicated oil capture pan laser aligned before, have still had some accidents.
You need to understand that 'premium' diesels are not a separate product to 'normal' diesels like super unleaded is, it is merely the same base grade of diesel with a double shot of additive in it (it still a TINY amount, i cant give figures but its still way less that 100ppm). Yes it might affect the cetane rating etc but its very very marginal and imo not worth it.
There is only one supermarket derv that has no additive that I know of (the ones who like to think they are a 'market' /cough)
(Source - Its my job, not internet hearsay and marketing nonsense)
Well, a few months into my ownership it (my 1.6 diesel Focus) seems to have settled on 53mpg overall and I’ve noticed it’s producing far less smoke than it did when I first bought it, it seems to have stopped continuous attempts at DPF regeneration as well.
I’ve used VPower diesel since I bought it, it’s either helping or it’s purely coincidence.
Don’t think so, it rarely gets out of town which doesn’t help, it averaged 65 mpg on the journey back from Chester when I bought it, my partners old 12 plate model (which she owned from 5 to 50k Miles) averaged 55 overall.Is it broke. My 2.0 Mondeo is getting 66+ at the minute.
I definitely get higher mpg figures when i use additives. So premium should definitely help.
Town driving is fair enough. Driving through Manchester traffic drops mine to about 60.Don’t think so, it rarely gets out of town which doesn’t help, it averaged 65 mpg on the journey back from Chester when I bought it, my partners old 12 plate model (which she owned from 5 to 50k Miles) averaged 55 overall.
I’ve read changing the fuel filter can help mpg with these so may give this a try at some point.
Costco changed to 97ron unleaded this year.Costco get their fuel from the same refinery / supplier as Tesco and apparently it's the same mix. May be worth giving it a go
Manchester traffic is not as bad as Cambridge then, thought it had #1 slot o/s London.
I would still be concerned by the Redex alternative, you empty this expensive can in the full tank, does it genuinely mix in well ?
ok - I had though whole can was necessary, but maybe you get same effect as V-power with smaller quantityI put 50ml in the empty tank then fill up, don't use Redex. Archoil AR6900-D Max buy it in 1 litre bottles, works out at about £1 per tank.
They no longer offer 99 Ron.
Their fuel comes from same supplier as Esso now.
Yea, 97 and 95.i did notice that last time i filled up. the ron was less. is it 95 and 97 they do now?
Around here (midlands) COSTCO fuel comes from Greenergy and it is their standard blend to keep costs down and ordering flexibilty - Greenergy also supply Sainsburys and TESCO around here, Greenergy also supply hundreds of ESSO stations. What blend these all use I don't know but I would assume all but ESSO use their standard blend..Costco changed to 97ron unleaded this year.
I read COSTCO add a custom additive during delivery but I didn't see this during a delivery. I wondered if they added it at the start the mix would be really strong and if at the end, what about all those people filling up during the delivery who got no additive? Maybe I will email and ask.
The cheaper blends are 'cut' with EU-permissable waste products such as 5% bioethanol and now 1.5% biomethanol aswell. Under some EU scam (EU scam not industry scam) these are double-counted as renewables and waste recycling and they get rebates and incentives to try and limit the EU fines due in 2020.
It is a 'waste product' for accounting purposes The French lobbied hard to make virgin mollasses classed as a waste product from which they produce ethanol and can count it 5 times when used in road fuel. It's crackers.As to bio-ethanol it’s not a waste product, quite the opposite
Sorry to revive old thread but something that happened recently made me remember it.
I had a check engine light on my diesel RAV4 recently. Took it to my mechanic who couldn’t find a thing wrong with it. He asked me where I was buying my fuel and I told him my local supermarket and he was adamant I should be using ‘good quality’ fuel, IIRC he suggested BP or Esso. He said the fault I’d had would most likely not reappear if I switched to a better fuel.
Anyone experienced anything like that before? Having problems on ‘low quality’ fuel? I’m a bit sceptical but this is a really good mechanic.
MK2 D4D? When it happens again, start with cleaning the MAF, then replacing the fuel filter, then testing/replacing the SCV’s or driver. It’s a ‘fun’ game to play
