On BT infinity is the upload counted on the 300 gb limit?
Yes.
Zen is £30 a month for 100gb limit and £75 installation
MW
My flat is 150 metres from the new BT fibre Cabinet and was wondering what sort of speed I should get if I take up Bt infinity? There web site quotes 21 meg
Borich
My infinity conection started at 38mb but it fell over the first few months to the quoted level of 21mb where it has stopped for now. With out line stats it is impossible to telll what is causing the drop in speed and BT will not investigate un less the line falls below 15mb
Interesting, where did you hear that? Over at thinkbroadband they say it's too tight to fit any more lines in than the 288 it supports as standard, another cab would be needed.According to an engineer for one of the ISP's, your sync speed depends a lot on how many people are using the service on your cab, as the equipment inside isn't that great. The Sync speeds BT quote are for what you will achieve when the cab modem you are connected to is almost full. They will be installing an additional modem for future signups to the service, but unless they go to the effort of redistributing half the lines from the full modem to the empty one, 21Mb is as good as you'll get.
http://forums.thinkbroadband.com/fi...e-first-full-cabinet.html?view=collapsed&vc=1
Don't think any of them are engineers though.
Right so when you said "They will be installing an additional modem for future signups" you meant in a second cabinnet, I thought you were saying in the current one which isn't what I've previously read but it's not a definite conclusion atm. You nearly throw a spanner in the works thenPresumably as you mentioned they have to put in another roadside cabinet for the second modem/UPS/cooling system set. I don't recall where I read it though. If demand is high enough in the area that they need a second unit I can't see them complaining about the expense of fitting one.
Brilliant,I'm going to meet the people at Bt tower who run the fibre project and if you have any questions I am happy to put it to the guys running the project.
One more for you borich_planner,Brilliant,
How many lines can be connected per cabinnet?
What happens to speeds as they fill up?
Once full can extra slots be added into the same cab for more lines and if not can a second cab be added instead?
Why is P2P upload speed capped at 1Mbps permanently?
Can the stats from the VDSL modem be accessed?
All I can think of atm.
Thanks.
I'm going 22nd December so if anything else comes up let me know. Just gotta hope the people who run the project know what they are talking about![]()
When can the 60/15 Mbps upgrade be expected, would the DSLAM need upgrading to support it?
Cheers.
mine says 7mb and 500k upstream for fibre to the cabinet, lol, dec 31st, id say it may be near 15mb though, still better than the 2.5 i get now.
