As most of you will know the home hubs are pretty useless.
I'm after something that will replace the box entirely, so modem/router facilitys, has strong wifi and good stability..
Please can you advise what you have used and what works well and doesn't cost more than £200 ish..
Would any of these work given the correct settings being applied to their rom?
https://www.overclockers.co.uk/peripherals/networking-and-wireless-lan/routers/adsl
Many thanks
Many thanks
