BT Homehub 2 broadband light problem
18 May 2011
Hi guys
Ive enabled the lights to flash on my router so i can see activity etc
However my broadband light is constantly flashing and only the broadband
The wireless light remains solid
Ive unplugged all ethernet leads and disconnected any wireless devices and its still flashing. No computers switched on etc.
Is there anyway i can tell why this is flashing?
Its doing it constantly with maybe a 2 second gap in between?
Any ideas lads?
And how can i m onitor the connections?
Thanks
OP
18 May 2011
Are you actually able to go online? Perhaps it's just indicating activity on the connection.
yeah i can go onlkine mate
but even with all the wireless connections disabled and ethernet leads unplugged its still flashing.
Ive done a router factory reset and changed all the encryption keys etc and its still doing it lol.
Its bugging me more then anything as im not using the internet when its doing it.
13 May 2011
Even when you're not using it it still sends packets to keep the connection open so I would assume it's flashing because of that?
13 May 2011
I can't find anything that mentions a flashing blue light. As you've tried all the basic stuff it might be worth giving BT a bell and asking them.
25 Aug 2010
Your outside line, is it ripped/torn? water damage would be my guess...
it happens quite a lot according to my bt engineer mate, but they are not the most relaible...
phone them up in anycase.
