I want to get stuck in.
You might notice the fan shroud on the GPU is grey. I use the genesis RAM myself, it's looks matte grey in the pics but it is actually metallic. Thought it would look good myself, had the LP corsair vengenance been available I might have spec'd that, depending on price.
thank again for all your help. I will definitely get some pics up. And no doubt I'll ask a few more q's when it all comes
90 days and 250 posts = free P&P. You could always cop a heatsink you really want later with the free P&P, or try and cop it as a gift come crimbo lol
Surprising how many Lincolnshire peeps here! Good luck with the build OP, post pics if you're able, helps delay the upgrade itch for us afflicted forum dwellers for a few more days![]()
Did you want a cheaper alternative or are you happy with that GPU?
Good to go mate but that 7850 GPU has shot up £20Did you want a cheaper alternative or are you happy with that GPU?
The Zalman Z9 comes with an extension for the aux 4/8 pin. I've used that PSU in the Z9 the other cables are long enough too. The reviews for that PSU do say the cables are on the short side but this is only an issue if you have a much bigger case.
EDIT
YOUR BASKET
1 x Asrock Z77 Extreme4 M Intel Z77 (Socket 1155) DDR3 Motherboard £101.99
Total : £101.99 (includes shipping : FREE).
That's the baby mobo you are talking about. I spec'd the ATX size mobo, it will fit in the Z9. The SSD is sata3 so you use the sata3 ports on the mobo (the grey ones).
