maybe he was?
was only saying, maybe its a point to work on? apart from that it was great, i subscribed to you on youtube as well btw
maybe he was?
Quite a few have mentioned so maybe Gibbo can support this and we can do another series of videos for mid-range and then high-end. I'd certainly be up for doing it and it seems to be what people wantVery good video, would be cool to see you do a mid range build (£700-£800) and a high end build (£1200) and compare them.
You should do a how to build guide
maybe that came across! Thanks for the sub mateA basic one? What kind of level would you like to see it at?
Sounds like a plan. When I'm back from CeBIT I will see about arranging something - cheers for the feedback mate.One that actually takes the time to address the all the places where the cables go and where all the ports belonged. Like the front IO ports.
No problem and do you know the nzxt phantom review can you put some comparisons into its article for the thermal performance so we can see how it is against the other cases like the bitfenix colossus.
). This is the latest one: http://www.vortez.net/articles_pages/enermax_hoplite_review,10.html we now do comparisons instead of just the standalone thermal reporting as its much more useful to have them side-by-side to compare.Perhaps you should be a bit more in depth? starting from the case stand-offs and onwards?
That is the only down-side to doing buyer's guides/builds. But if we can do them frequently then they remain up to date. We're hoping that OcUK will support this going forwardMy only critasism would be any build you do won't be the same bang-for-buck in say, 2 or 3 months down the line. Video was great, though, looked professional and would like to see more people taking interest in making their own builds.
Hey mate, did you have a link for the RAM you are referring to? The kit that I recommended has some really good CAS timings that are quite a lot tighter than most of the 1600MHz kits around at the moment!Mishima, just a quick question. I re-read the article again today and noticed you're placing some 4GB £55 RAM in the system. With some cheaper, seemingly equal perfomance RAM on offer here at the moment, why did you choose the RAM that you did? Does it offer significant perfomance advantages over the cheaper alternatives?
Those are good examples, but are slightly higher voltage and come with CAS 9 timings so overall are going to perform a little worse than a CAS 7 kit that I recommended. Lower CAS latencies (and tighter) are going to lead to better performance in a range of activities.Erm this maybe -
http://www.overclockers.co.uk/showproduct.php?prodid=MY-104-GL&groupid=701&catid=8&subcat=1517
or this?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-203-CS&groupid=701&catid=8&subcat=1517
Not a RAM expert so I apologise if I'm overlooking something obvious![]()
