My Dad loves gaming but doesn't know much about computers so I'm going to build something for him. I'm no expert but have built a few systems over the years.
He wants something that will run anything he throws at it while also being fast enough to run VR when he decides on a headset. He has a budget of around £1500 for the PC and £1000 for the monitor although both can be moved around if something is a bit more/less. I don't want him to spend too much so I've specced up the below system after some serious scouring around (mainly here, so thanks already!). I realise that the Aorus 2070 Super is overpriced but he wants the direct USB-C for the virtual-link availability (should it ever come to fruition) and that card gets good reviews being a top of the range 2070 Super. I also know that the 3900x is overkill for gaming and Lightroom use but I know him and he's not going to want to muck around with this ever year or two to keep it top notch. I'm thinking maybe get him a 3700x and we get a 4000 Ryzen in a couple of years, will the rest of the kit stay the same assuming we could do that with the below?
Also, overclocking, RGB and fancy cooling matter none. He has a Fractal Design case (R6 with no window I think) so won't need it to look pretty, just run well. I didn't spec any cooling as the included Wraith prism looks fine, or are we better getting a https://www.overclockers.co.uk/arctic-freezer-34-esports-duo-red-cpu-cooler-2-x-120mm-hs-075-ar.html to keep things cool?
My basket at Overclockers UK:
As for monitors he likes the look of the Alienware AW3420DW but I don't know if it's worth £1100 and think he should get something like https://www.overclockers.co.uk/aoc-...wide-curved-led-gaming-monitor-mo-04t-ao.html as it ticks similar boxes (1440p, 120HZ, 4ms).
I'd appreciate any expert thoughts on the above! Thanks in advance.
- 1 x Gigabyte X570 AORUS ELITE (AMD AM4) DDR4 X570 Chipset ATX Motherboard= £182.99
- 1 x AMD Ryzen 9 3900X Twelve Core 4.6GHz (Socket AM4) Processor - Retail= £449.99
- 1 x Corsair Vengeance RGB PRO Black 32GB (2x16GB) 3600MHz AMD Ryzen Tuned DDR4 Memory Dual Kit= £199.99
- 1 x Aorus GeForce RTX 2070 SUPER 8192MB GDDR6 PCI-Express Graphics Card= £559.99
- 1 x Corsair RMx Series RMx750 750W '80 Plus Gold' Modular Power Supply (CP-9020179-UK)= £107.99
- 1 x WD Black 1TB SN750 M.2 2280 NVME PCI-E Gen3 Solid State Drive (WDS100T3X0C)= £169.99
- 1 x WD 1TB SDD + 2TB HDD Bundle= £161.94
Total: £1,844.58 (includes shipping: £11.70)
