Build outside of case
30 Oct 2013
When putting components together and testing on top of motherboard box is it ok to do this for the length of time it would take to install OS and updates, say a couple of hours or would it get too hot.
I've run systems like this for ages.
Just make sure you put the board on something non conductive, phone book works well.
Add a fan next to the board if your worried about cooling, but for a quick OS install you will be fine.
