I'm not sure if you're being sarcastic here, but I'll assume you're not.
You may not have tinnitus, but I guarantee you've got noise induced hearing loss in one form or another though.
Having just carried out a 18 month noise survey in the music department at the university where I work (because of the new HSE regs which now include entertainment industries such as music etc) it's pretty obvious that out of all the instruments I've sampled that the drums are the worst. It's not uncommon to find a drummer kicking out about 100-105db when measured at 1m with peak levels hitting 130dB or more.
To put this into perspective, because the dB scale isn't linear, for every 3dB you go up, the intensity of the sound doubles - and as such, the time you spend being exposed to that noise should be halved, else you risk hearing loss.
The HSE regs are time weighted against a typical 8 hour working day. The second (important) action level is 85dB.
85dB - 8 hours
88dB - 4 hours
91dB - 2 hours
94dB - 1 hour
97dB - 30 mins
100dB - 15 mins
103dB - 7.5 mins
And so on...
There is a serious culture issue in the music industry which *is* leading to premature hearing loss. Even orchestras are having to evaluate their positioning and even the pieces that they play now, because the levels a decent brass section can kick out are deafening the flutists at the front of the pit!
So - 14 years of drumming with no protection will have taken it's toll on your ears. The damage is often initially not perceptable without a proper audialogy test since the damage tends to effect the higher frequencies the ear percieves first.
...and we've not even covered transient damage (the most damaging sort of noise for the ear) and guess what kind of noise a drum kit is mostly made up of...
Even a 6 quid pair of washable flat response plugs are better than nothing, the best choice being a set of custom moulded plugs, but they cost about 120 quid for a proper pair. Expensive, but I don't think you can put a price on your ears, since they don't ever heal up or repair themselves. It's a bit like looking at the sun all day and then saying 'Blind spot? Nah, you've got weak eyes mate' heheh!
