1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Bye bye 6 series - Ideas for baby friendly car
Discussion in 'Motors' started by LordVader, 2 Oct 2019.
  1. Peerzy
    I bought my F12 shortly before my first was born. The first size car seat (0-18 months) fits in fine and I'm sure the next one up will as well. Buggy would probably be tight in the boot due to the opening but I'm sure I'd get it in if I needed.
  2. LordVader
    Hitman
    I thought baby's have to be rear facing for the first 15 months??
  3. Mysterae_
    Wise Guy
    I'm wracking my brain trying to remember, it was a while ago! You're probably right and my other half would have had the child's safety paramount.
  4. GinG
    Sgarrista
    If you are after an SUV.
    Skoda Kodiaq
    \closethread
  5. Scania
    Capodecina
    This.
    Get a pram to suit the boot (assuming you’d struggle to put a pram in it which I doubt) not the other way around.
    If you want to change the car regardless, rock on, changing it for a baby is plain silly if you otherwise are happy with it.
  6. xs2man
    Mobster
    I found it pretty easy in my Edition 30 when I had that and the kids. The seats did flip forward enough so I could climb right in with plenty room. I didn't find it a hassle at all really. Baby seat with decent ISOFIX base, and it really is no issue. It's only really beginning to be an issue when they are a bit older. When you have to use the actual seatbelt, and they aren't quite old enough to use it themselves. That couple years is slightly more awkward in any car, but actually easier in the 3 door cars, because rather than leaning right over the kids, you can climb right in and get much easier access to the belt buckles.
    Yeah, I would consider one of these also.
  7. Peerzy
    They do by law. My son is now 14 months old so will be going into his front facing one very shortly but he's fine in our rear facing (Maxi Cosi Pebble) car seat in my F12.
  8. LordVader
    Hitman
    I take it he is in the front seat w(rear facing) in the car?
    Don't want to sound weird but if your maxi Cosi is in the rear could you take a picture with the seat in? Also is that with isofix base?
  9. Peerzy
    He's in the rear seat behind the passenger (as I'm very tall in the drivers side). No ISOfix base as that's in my wifes car (Alfa Guiletta).
    Picture of him loving the ride at just over 9 months old:
    <img removed>
    The fit would probably be better and easier in the front seat but I had a passenger in there and hadn't disabled the front airbag so my son went in the back.
  10. LordVader
    Hitman
    Ahhh F12 just noticed convertible.
    Not sure I could even get a baby seat in the rear of a coupe without whacking the seat/trim. Suppose could give it a go.
  11. Peerzy
    Probably easier than buying a whole new car. Can also go in the front seat with the airbag disabled.
    Do you have another car? I think an F12 / F13 as the primary car for the baby would be annoying, but as a once or twice a week trip it's perfectly fine.
  12. Havana_UK
  13. Uncle_Gravy
    Mobster
    Sounds like you need a 6 series gran coupe, /thread
    NEXT!
  14. Drumroll
    Wise Guy
    May not be practical if needed to carry the baby 4 times a day, but if once a day, should be fine.
    There's plenty of options for baby car seats and prams.
    Also if fitting a baby car seat, you can find some protective fabric/padded mat as Car Seat Protector for Child Seats - Premium - Protects Car Upholstery from Child Seats, Dirt and Stains - Universal Size - Thick Material - Non-Slip Backing - Mesh Pockets - Easy Cleaning. https://www.amazon.co.uk/dp/B073PJHPGK/ref=cm_sw_r_cp_apa_i_zpBLDbB5RXJPR
    But if changing cars is imperative, no need for a full size SUV, a estate may make more sense. The extra rear doors on anything than a coupé would make all the difference, and a coupé, even the ones with 4 doors, due to the sloping roof may not be practical.
  15. Le Clandestin Brun
    Sgarrista
    [​IMG]
    [​IMG]
  16. Desmo
    I've always thought SUV's are a bit crap for boot space... much better off with an estate.
  17. The_Baron
    Wise Guy
    We’ve a chair that rotates so can be front or rear facing. Makes it very easy to get the wee man in and out. Can confirm the X3 works well as a main baby moving vehicle. We’ve quite a large pram and brought it along to the showroom to check it fits before buying the car. They through in a boot liner too. Great way to keep the upholstery clean as the pram wheels get muddy!
  18. timmeh
    Mobster
    6 Series GC will be fine. The sloping roof can get a little tiring for the 2 years that they’re rear facing as you have to ‘slide’ them in head or feet first but after that it’s fine
  19. theone8181
    I'm confused op, I have an almost 6 year old and a 3 year old. I've had my e92 m3 for just over a year and prior to that a 911. Space wasn't that much of an issue in the 911, even when rear facing. In the e92 there's loads of space and it's even easier now they can both undo their seatbelt although there are both in backed boosters. I have no experience of the i-size seats, although they will be a bit bigger but in a 6 series (which iirc is basically a coupe version of the 5 series) I can't see how you wouldn't have enough room. I found with rear facing just get a bit of momentum in the child and swing them into the seat, even easier if it rotates I think my wife had a joie 360 that did that which worked well.
  20. Le Clandestin Brun
    Sgarrista
    Luggage space is the key.
    Wife does fine with a 3 series as a daily with the kids but all she can fit in the boot is the double pram and one or two bags shopping. When needing to take more (travel cots, suitcases etc.) my 5 estate was only just big enough so we bought a roof box too, so it was big enough for all their and our stuff including double buggies and travel beds etc.
    Sure your can pack light and cram it all in, or you can just get a car with more room and save on the hassle.
